My amp heats up
Car: 1986 Camaro SC
My amp heats up
after like 10mins or so of playing my subs, (****ty ones i ahve here) my amp gets pretty warm, it's a MTX 2300, is there anyway to fix this, or is it not too bad as long as it doesn't start burning up??
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Hmm. An amp that heats up.
I not sure if you know this or not, but an AMP is a big Heatsink.
Do you know what heatsinks do? They are designed to dissapate heat. Which is what most amps are designed to do.
As long as it does not trun itself off, you are fine.
Don't worry about it, all amps get hot. I'm not too sure about your model, but most of the newer models have some type of safty circut that shuts the unit down if it is getting tooooo hot.
Sorry for the late post, but I could probably cook eggs and hashbrowns on my pair of Soundstream Reference Class A 3.0's even at moderate volumes! Seriously though, unless your amp is cycling into thermal protection mode, you are fine.
raymondandretti
Sep 27, 2015 06:43 PM
