Correct Way To Wire Interior Neons, And Fuse Question
Old Apr 8, 2002 | 05:06 PM
EjBaL's Avatar
Ok, I posted this in the electrice section but no one seemed to care so I will try it here. I have a neon in the trunk and 2 little tube neons under the dash. I currently have them all hooked up to one switch, and the power for the switch is hooked up in to the inline fuse for the amp power wire. What is the correct way to hook up these neons, directly to the battery? Also I have a 200 watt pioneer amp running a 15" sub, the fuse on the amp is a 20, and the inline fuse on the power wire is also a 20, what should the inline fuse be? Is 20 too small? thanks alot for any help.
Old Apr 8, 2002 | 05:34 PM
TrueBlue91RS's Avatar
What is the current draw of all the neons combined? Chances are, it'll be minimal. If it's not, then you'll have to add that current draw to the 20 that your amp pulls and put in a new fuse at or above that level.
Still, you could adjust the inline fuse (I assume you mean the one within a foot of the battery) to about 25 or 30 amps for your amplifier alone anyway. It's okay (and most often preferrable) to have some "headroom" on that one. But make sure the fuse directly before your amp remains at 20 amps.
As for how to power your neons, I don't really know 'cause I've never done any. You could split them before your amp fuse, I guess. But you might want to put a fuse on that wire as well.
One thing that you could do if you wanted to lose the switch is put in a relay that works with your amp's remote turn on. That way when your system's on the neons will come on automatically.
Old Apr 10, 2002 | 12:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't you get noise from the neons going into the amplifier? Seems you'd get a buzz or hum out of the amp by tapping into it's power wire.
If I were you, I'd run a relay. Use the relay as the "middle man" between your switch and the neons.
"magnet side" of relay: Ignition terminal of fuse box, manual switch, relay pin 85. Relay pin 86, ground.
"switch side" of relay: Wire to battery, fuse (close to battery), relay pin 30. Relay pin 87a, neon tubes. Neon tubes, ground.
Like TrueBlue91RS said, I think the current draw for neons is minimal. 16 gauge wire should be fine from the battery to the trunk.
I have a purple neon under my bumper from '94 (back when I was cool, haha), that I wired with a relay, in line with a "cop!" switch. I wired the relay so that when I put my lights on, the neon came on. The "cop!" switch is wired between the light switch and the relay, so if the switch is off, the relay never activates. Actually, the "cop" switch has turned into a "when I feel silly, I turn the neons on" switch. It's been off for a lonnnng time.
Old Apr 11, 2002 | 11:01 PM
Greg Kuhlmann's Avatar
splice into the power wire going into your CD player... then run a toggle switch off that... i did it!
only bad thing is that you have to have the car on the acc. to have the neons and stobe lights going.... worked for me!
that and for another neon i spliced into the dome light and ran a switch off that.
Old Apr 12, 2002 | 02:17 AM
84,86,88Z28's Avatar
no no no no,
heres what i did,i have two 12 neon tubes,4 license plate screw lights,and strobed in my tailights,now,i have all these wired into one switch,prolly isnt to safe,but it has worked so far,anyways,the are wired into my switch that is mounted right behind the shifter,i wouldnt put it there again,and the switch is power wire for the switch is run into the haz. fuse,just wrapped around the fuse and pushed back into place,this way,you can turn you neons on and off whenever you feel like it,if you just want your neons on at night,you can leave them on,and still take you keys ,just what i did,
Old Apr 13, 2002 | 03:19 PM
EjBaL's Avatar
thanks for all the replies, I got a question, what is the haz fuse? Just wondering thanks again
Old Apr 15, 2002 | 08:44 PM
the emergency hazard lights,your 4 ways,they always have power to them,so as long as u wire into them,and put a switch on it,you will be able to turn them on/and off at anytime.
Old Apr 15, 2002 | 10:45 PM
cbarry's Avatar
Where is the best place to put the neons? I have a Blue '91 rs. I want to be able to see them on the inside and on the outside. Thanx!
Old Apr 16, 2002 | 10:13 PM
EjBaL's Avatar
well in my corsica, I have a 2 neons under the dash, one on each side to shine on the floor, then i have 3 ports in m back seat with a neon behind them in the trunk that flashes, I also have a neon around the cd player. Here are some pics, u kinda get the idea
Attached Thumbnails Correct Way To Wire Interior Neons, And Fuse Question-flash-neon.jpg
Old Apr 16, 2002 | 10:15 PM
EjBaL's Avatar
wrong pic there, but its right under the dash on each side, here is one of the ports, they go up and down, the pic might be a sideways one I am not sure.
Attached Thumbnails Correct Way To Wire Interior Neons, And Fuse Question-neonport1.jpg
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
