Anyone ever run a 2bbl on a v-8? Results
Old Apr 14, 2002 | 04:31 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Just wondering. I'm not really serious about doing it. I just wondered what advantadges/disadvantadges there would be. It seems as though a 350 with a 500 cfm Holley 2bbl sitting on top of the edelbrock sportsman vic jr. intake (or maybe a weiand single plane w/ adapter) would be a great streetable, easy to tune torque monster with the right cam. Am I wrong? Has anyone messed with 2bbl's on a V-8?
Old Apr 14, 2002 | 10:36 PM
iroc22's Avatar
One problem is jetting it right. You cant get a blend of gas mileage and power like you can with a 4bbl
Old Apr 14, 2002 | 11:11 PM
JRoy91RS's Avatar
Engine: 355
I think I see your point. Do you think the jets on a 2bbl would have to be larger than they normally would on, say, a 4160? I could see where efficiency might be compromised, especially as compared to vacuum secondary carb.
Old Apr 15, 2002 | 01:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1st, 2bbl carbs are rated at a higher delta pressure than 4bbl's, so a 500 cfm 2bbl would not flow as much as a 500 cfm 4bbl.
2nd, because all of the air is flowing through two relatively large venturi, air velocity will be down, which will have a negative effect on fuel economy and throttle response. They were used on "economy" engines because it was more economical for the factory to put them on base V8 engines, not because they were more economical to operate.
But, there were a bunch of 350 and 396 Camaros and Novas delivered with 2bbl carbs in the mid- to late-60's. Class guys got a pretty good break using that carb, so had a lot of success running them on the strip. But, again, not the best street carb.
Old Apr 17, 2002 | 11:04 PM
1986redbird's Avatar
I once had a '70 firebird with a 350 2bbl and it ran like a scalded ape. would burn the tires off just by hitting the gas didn't even need to hold the brakes. I don't know about the mileage though, i was 18 and only cared about going as fast as I could get away with.
eightsixseven
Dec 16, 2024 01:50 PM
backtothe80s
Sep 5, 2015 12:39 AM
jahblah
Aug 12, 2015 05:54 PM
djmarch
Aug 9, 2015 05:27 PM
anesthes
Aug 8, 2015 09:37 PM
