Question about choke heater.......
Now I've got my choke to receive a proper voltage through the c/h relay only with the engine running. Questions? While engine runs should the voltage to choke heater remain constant or should the relay vary it? Or is the relay there to allow the choke to function only with the engine running? Will that constant voltage to choke damage it ?
Car: 82 camaro SC
Should get a constant 12V when the engine is running.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The relay turns power to the choke off when the car isn't running, ie. when the alternator isn't charging. This is why the choke light also doubles as an alternator light.
