Adjusting to run Leaner???
Old May 24, 2001 | 12:07 AM
CAMARO82's Avatar
I have an 1982 Z28 Camaro with a 350.. It has a Holley 600 four barrel carb on it. I don't know much about carbs but it is running really rich. Where do I adjust it to run leaner? Thanks
Old May 24, 2001 | 12:57 PM
82camaro's Avatar
Car: 82 camaro SC
When is it running rich. Idle, Just off idle, Moderate throttle, WOT. Basicly you have float level, idle mixture, accerator pump, power valve, and jets.
Start with the simple stuff, adjust the float level and idle mixture.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
86IROC112
Aug 17, 2015 02:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
