Secondaries wont close
I have a non-computer controlled Quadrajet on my 305HO. When I rev the engine past about 3000 rpm, the secondaries stay open. Anything below 3000 rpm and it idles down fine. What is going on here? Needa quick fix-carb going on different motor soon.
Transmission: 4L80E/4L80E
I think some clarification is needed. Are you talking about the upper air valve butterflies, or the lower throttle plate butterflies? Also, how do you know this is happening?
If the former, there's something wrong with the return mechanisms of the AV - either the spirial spring adjustment (or it's broken), or the choke pull-off.
If the latter, then something is binding the shaft.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Pac J
May 17, 2020 10:44 AM
