Air bleed adjustment on 1407 Edelbrock...
Old May 21, 2001 | 12:15 PM
Racerwannabe's Avatar
Has anyone changed the stock air bleeds on one of these carbs? If so how did you do it? My engine is loading up at idle even when I lean the adjustment screws enough to cause lean misses at idle. The symptom has to do with my accelerator pump, I can rev the engine a few times to clean it out and then the throttle response is great but if I let it idle for a few moments the off idle response gets somewhat soggy. The engine is in good tune, my advance curve is 15* at idle, 20* mechanical all in by 3000 and 6* vacuum connected to full time vacuum. My cam really likes all this advance at idle and I can get a very nice rumpity idle but, as I said, it loads up. Thanks for any help!
RW
91 RS/3.1 - Stock except stereo system, daily driver.
86 IROC - T-Tops, 350/TH350 w/shift kit, 2600 Stall, 3.42 geared 12 bolt, Performer 750cfm, Performer RPM, Comp Cams 280 magnum, Hooker 1 5/8" shorties, Flowmaster Y pipe, 3" to Flowmaster 2 chamber Dual outlet.
Old May 24, 2001 | 03:49 PM
Now, don't everyone reply at once!
Old May 30, 2001 | 12:43 PM
Well, one more try then I'll be on my way...
Old May 30, 2001 | 02:25 PM
FastBroker's Avatar
I can't help (no real Edel experience) you but I am sure a Carb Tech at Edelbrock would be glad to help you diagnose and fix your problem. Give them a call?
specialized
Jun 18, 2022 09:26 AM
backtothe80s
Sep 5, 2015 12:39 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
perZ
Aug 15, 2015 01:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
