How do you fabricate the PCV breather to an OEAC?
The hose that plugs into the back of the air intake assembly. is thier an adaptor for it? Can i just remove the hose? I wanted to get the K&N OEAC but dont know what to do with that hose. Thanks
87Camaro RS
305 carb.
Just got it so working on mods
87Camaro RS
305 carb.
Transmission: 4L80E/4L80E
I don't know about the K&N specifically, but most open element replacement air cleaners come with a bolt-on nipple that requires punching/drilling out holes in the base plate.
Another option is to plug the hole in the valve cover and get a vented oil fill cap. Same effect, but would be the same side of the engine as the PCV valve, so total removal of vapors would be reduced (slightly). But, crankcase pressure would be controlled fine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Pac J
May 17, 2020 10:44 AM
Royal_Z
Sep 30, 2015 08:45 PM
