Fuel Pressure regulator?
Old Jun 6, 2001 | 09:30 AM
shiner16's Avatar
I was wondering which regulator I should use? I am using the stock v6 fuel tank and pump. I would like to spend less than 50-60 dollars if possible. I usually order stuff from Summit or Jeg's. Do they sell any good ones for this price or less, or do I need to spend more $$$? Thanks in advance.
'86 Camaro base coupe, awaiting the 355:
.030 over, studded 2 bolt main, #487 casting heads w/2.02/1.60 valves, Crane Energizer cam, Performer intake, Edelbrock 750 carb.
Low-Budget and proud of it!
Old Jun 6, 2001 | 06:45 PM
scott's85T/A's Avatar
I'm in the same boat,I put a V-8 in a 2.8 V-6 car and can't find a regulater to reduce the flow down from 45psi for less than $80.00,mine was the multiport, some of them (TBI i think) are only 15 psi.I guess I'll have to drop that tank after all!!I hope someone answers this soon.
Old Jun 6, 2001 | 08:07 PM
Jester's Avatar
There are none that will do it for less that $80.
You best bet cheap wise is to get a decent mechanical pump for ~$35, drop the tank and replace the pump with a pickup (read, section of hose).
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
