Black smoke
Old Jun 14, 2001 | 03:32 PM
WS6 Berlinetta's Avatar
Black smoke
I just threw on a carb I rebuilt from the junk yard and I've noticed it idles real low and blows black smoke out the exhaust when I start it the longer it sits the worse and longer lasting it is. This only happens after a few hours any ideas? It runs fine after allitle bit but it's like it's running super rich after it sits for a while.
Thanks,
Randy
'84 360ci WS6 Berlinetta
Fastest Berl In Cali
WWW.SDFB.ORG
Old Jun 15, 2001 | 07:43 AM
ERIC'86IROC's Avatar
Did you try to adjust the idle mixture and float level? Check the power valve if its a holley.
Are the needle and seat new?
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
[This message has been edited by ERIC'86IROC (edited June 15, 2001).]
Old Jun 16, 2001 | 08:28 PM
Damon's Avatar
The choke could be adjusted wrong. The choke SHOULD open after a few minutes of running time, however. Run the engine for 5 minutes. The choke plate above the primaries should be vertical or nearly so by then. If it runs fine once the choke is off then check the following:
When the engine first starts (cold engine)the choke should "pop open" about 3/16" immediately after startup. This is done by the vacuum diaphragm on the pass. side of the carb. If it's not working or not adjusted correctly you will get a really rich mix for about the first 2-5 minutes.
If you're stuck, shoot me an email and I'll try to help out.
Please note that computer controlled carbs can have MANY other things wrong with them that can produce simialar symptoms.
Old Jun 19, 2001 | 11:53 AM
I think it's the choke I readjusted it and now I get a light smoke for a few secs but nothing like before. I've already tuned the idle with it hot in drive. I think it's just a matter of fine tuning since I don't have a an angle guage. I also have a slight bog but I'm not done tweaking the secondaries. See my new post for more.
R
WWW.SDFB.ORG
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
