Having Big trouble with my carb.
Old Jun 19, 2001 | 07:04 PM
EnTwisted_Iroc's Avatar
I have a 73 olds Omega,nova clone with a 350 rocket engine. On the engine is a Edelbrock RMP manifold, edelbrock 650 elecit. choke and dual exhaust 2 flowmasters. Its been shoting gas out of the carb. and will start on fire its happen 3 times on me. I changed the timeing chain and tuned the carb and fixed the choke but it still backfires out the carb. What is the trouble with it.
89 Iroc-Z 5.7 350
Old Jun 19, 2001 | 11:57 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
The last time my engine was backfiring like crazy was when all my plugs were completely covered black. It was running way to rich.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Old Jun 22, 2001 | 03:08 AM
They said it was runing lean.
Old Jun 25, 2001 | 12:37 PM
greearhr's Avatar
Well! You know how "they" are. Actually if gas is "shooting" out of the carb you may be way high on the float setting or have some crap in the inlet valve. Sounds dangerous.
Beartracks
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
