Combo Selection?
Old Jun 21, 2001 | 08:32 PM
Fade07W's Avatar
Combo Selection?
This might get moved but I was hoping to ask you guys what kind of block/carb setup will get me into the mid 12's. I have an '87 TA with the 305 and 4 barrel. I would like to do it on motor alone. I am thinking a 400 hundred with maybe a Holley 750, a mild/aggresive cam, and some fully ported cast iron heads. Would this be enough and if not what do you guys have in mind? By the way these will be done with either a 4.10 or 3.73 rear end ratio and a 700R4.
Rob
Old Jun 22, 2001 | 06:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 400 hundred engine? That's 40000, or 40,000 cubic inches - That should do it!
Seriously, though:
Forget "mild" cam - agressive is in order here. Probably don't need wild, though.
Higher stall convertor to match the cam. Better get that TH700 built solid.
Traction - lots of it, to go with the 4.10 gears. Get everything Spohn offers.
Tuning - needed in same quantity as traction.
Say goodbye to daily driving.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 25, 2001 | 03:02 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
350 w/ 10.5 compression, forged flattops, forged crank. Warmed over Vortec heads. Performer RPM intake, XE274hydraulic cam. 780 vac sec 4150 holley, SLP1 3/4" headers. Built 700R 3000stall, modify the rear suspension, 3.73 gears, and cheaters... that's the combo i'm banking on
Should do the job.
[This message has been edited by Pony Killer (edited June 25, 2001).]
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
roysatikas
Sep 22, 2015 08:15 PM
Mdenz3
Sep 17, 2015 08:36 AM
