Help!!!, Should I buy a new carb?????
Car: 99 Formula
Axle/Gears: 342
I just bought this carb about 4 months ago and would hate to have wasted the money. Lately my car doesn't seem to be pulling as hard and was wondering if it had something to do with the carb. I G-Teched my car and with the windows down ran a 15.75 1/4, which I would think I should least be at high 14's. I know nothing about working on carbs. and would have to pay someone to work on it, but I heard the Holley Street Avenger carbs are great but they are like $380. What should I do.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Car: 99 Formula
Axle/Gears: 342
Also the carb. is running rich, I have black powder on the tailpipes and am getting bad gas milage. The choke housing busted off but the car starts and idles fine, could this be causing me problems?
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
</font>
</font>
https://www.thirdgen.org/messgboard/...ML/000898.html
Quick answer to your question: Yes.
Longer answer: Without the housing, there is nothing to keep your choke open. So, choke closes or partially closes, starts & idles fine, runs rich and chokes flow & power other times.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
