Don't want to make the same mistake twice
Old Jul 7, 2001 | 06:52 PM
wildman923's Avatar
OK had my car running for a day before it decided it wanted to be a true firebird (emphasis on fire) and in this time ran into a few probs. 1st was the carb, with the computer hooked up to the carb It would not start once we got it timed in. With the computer disconnected the carb ran too rich. What's the best solution to fix this prob? New Carb? New Chip? But if I get a chip where can I get one made to fit my cars engine? I have a stroked 305 cam specs are 224-230 dur @50 with .477 .480 lift and a 110 lobe sep. For now I'm using the stock exhaust,intake and carb.
BOB
'84 TA
334 SB
"041" heads
+ Dual snorkel and cowl air intake
More to be added once I harvest the money tree.
Old Jul 11, 2001 | 04:32 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Hmmm, i don't know what your problem is, but i can tell you what it isn't...the chip/computer. I've seen CCCS run a worn out L69 with a bigger cam than yours just fine.
You say it won't start, how about once it is warmed up, will it start then with the MCS (thing on top the carb, assuming thats what you've been unplugging) plugged in? If so, sounds like you have a simple choke adjustment problem. With the MCS unplugged it will run richer than rich, which could help cover a bad choke adjustment.
If it won't start w/ the MCS plugged in at all, then i'm stumped for now.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jul 12, 2001 | 05:55 AM
wildman923's Avatar
It would start with it hooked up but I had to back the timing way off, and sit and crank on it for a good 20 seconds before it would even pop.
BOB
'84 TA
334 SB
"041" heads
Grant2k
Jul 10, 2018 04:01 PM
TheExaminer
Aug 26, 2015 04:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
Fronzizzle
Aug 9, 2015 01:15 PM
