Attn Jester, others who have done TBI-carb swap. Dist. ??'s
Old Apr 21, 2002 | 04:28 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
ok, I bought the summit distributor with the in-cap coil and am not sure how to hook it up. There appears to be a black, red, and brown wire running from the inside of the distributor to a terminal on the in cap coil. Next to that terminal, it looks like there is a two prong socket for something to plug into. What goes there? How do I hook up my tach? The distributor came with no instructions. Should I just call summit?
thanks
Old Apr 21, 2002 | 08:13 AM
Jester's Avatar
The two terminals should be marked TACH and BATT. The tach terminal goes to the tach, the battery terminal goes to the 12v ignition lead. Both of those are on the stock remote coil, just run them to the new coil instead. I can't remember the colors off the top of my head, but that shouldn't be hard to figure out.
Old Apr 22, 2002 | 01:43 PM
JRoy91RS's Avatar
Engine: 355
thanks for the help. I realized that I forgot to order the pigtail from summit that goes from the dist. to the ignition/tach leads. D'OH! Those of you switching from EFI to carb will need this part.
Old Apr 28, 2002 | 10:34 PM
OûtlåwFørmûlå's Avatar
Jester what kind of fuel delivery did you use? stock pump and reg?
Im leaning toward doing to TBI to carb thing also........
Peace
Old Apr 29, 2002 | 09:46 AM
Jester's Avatar
I have a bulkhead fitting welded to the bottom of my tank, an external 140gph inline electric and a summit dual feed regulator.
Old Apr 29, 2002 | 10:48 AM
TBI305Camaro's Avatar
so when i do the swap i need the pigtail...then what? just slice wires to wires?
pjsparts
Oct 29, 2025 06:39 PM
$750 L98
Feb 1, 2025 02:25 PM
rubblerubble
Mar 13, 2016 06:57 PM
usafirebird
Sep 29, 2015 11:58 PM
86White_T/A305
Sep 21, 2015 05:28 PM
