Is 750 too much for a 350?
Car: 1989 Iroc Z L98
I am in the final stages of planning my engine, I will start construction in around 2 months. One thing that has been bothering me is the carb. I know I am getting a holley carb, but how many CFM should I get. I have been told that for a nicely built 350, (300+ hp), a holley 600 would be just fine. If so, what is the purpose of putting a 750 on. Is that overcarbing? Thanks
I have a 750 on mine and it's great. I have great throttle response from idle all the way 5500(I think the exhaust is slowing me down or it'd keep pulling). The 750 just leaves room for improvement.
'87 Bird 350 .060 over 700R4 + Lots more
YEP!
84 Camaro ZZ4 with HOT cam. Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (Best 60',Quarter Mile, MPH) (1.88, 12.91, 106.77)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
The Bowtie
I want just a very mild came, a 265 i think. does that sound right? after all i have learned about cars, i do not understand cams for ****. could someone explain it for me?
Car: 2002 SOM z28
Picking the proper camshaft is much more improtant then picking a carb IMO. You can't go wrong with a 750cfm carb, but a 600cfm may limit you a little if you go with a long duration cam. Something around a 262 duration isn't that much, but I prefer a 750...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
