Carburetor Removal
Old Jul 25, 2001 | 10:07 AM
Marin84L69's Avatar
Carburetor Removal
I'm going to tackle removing the carburetor so that I can have the throttle shaft bushings installed at a carb shop. Is there anything difficult with this procedure? I know many of you can probably do this in your sleep but for me it will be the first time. It's the original CC quadrajet. Any tips, suggestions etc.?? Thanks,
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
Centerforce DF Clutch
SLP 1 5/8 headers, high flow CAT, SS Exhaust
GM Motorsports Struts
Old Jul 25, 2001 | 10:23 AM
sleeper's Avatar
Nothing hard... just disconnect everything and be sure to label where all the hoses go back. It will be stuck on pretty good... a rubber mallet will help break it free... no screwdrivers.
Don't tilt the carb as you remove it or gas will leak everywhere.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
Old Jul 25, 2001 | 10:48 AM
Marin84L69's Avatar
Thanks for the information. Now I just have to find a rubber mallet!!
Old Jul 25, 2001 | 10:53 AM
Draug's Avatar
If the carb has never been off, chances are that the fuel line tubing fittings will be very tight. There is one fitting on the front of the carb and one on the back of the carb. Make sure you use tubing wrenches or you will round off the nuts on the fittings.
Also be sure not to scratch the top of the intake where the carb seals to it. If you do, you will have a hard time creating a seal there when you reinstall the carb.
Hope this helps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Stroopwafel
Sep 11, 2015 06:38 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
