running rich, help?
Old Jul 23, 2001 | 03:01 AM
82taGODD's Avatar
running rich, help?
my car is running way rich, and i was wondering if a carb rebuild and/or tune up will fix that. also could someone tell me what cfm means?? thanks
Old Jul 23, 2001 | 08:20 AM
Damon's Avatar
CFM = Cubic Feet per Minute. A measure of how much air a carb can flow. It's measured at 1.5" of vacuum under the carb. All 4bbls are measured using this value so it's relatively easy to compare flow ratings.
In a typical carb if you are running very rich it's usually because something has gone very wrong. If it's computer controlled loke the QJets used on many 80s era FBodys then the carb is likely not receiving a signal from the ECM (it defaults to full rich). If it's not computer controlled then there are a number of mechanical things that could have gone wrong inside the carb to cause a rich condition. They may or may not be things that a typical rebuild would address.
[This message has been edited by Damon (edited July 23, 2001).]
Old Jul 25, 2001 | 05:00 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you still have the stock computer controlled carb, the most common cause of running rich is a bad/misadjusted TPS. Do a search on this board and you'll find this covered many times, i don't have the time or energy to get into it now.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
