T.V. cable to holley carb?
i swapped from tbi to carb about 3 weeks ago and holley says i need a special bracket and button to put on the carb in order to get the shift points right. i have a 700 r4 transmission and i was curious if anyone else has had to do this. thanks
Car: 2002 SOM z28
Do a search on this forum for the exact number, or simply thumb through a Jegs/Summit catelog too. It is like p/n 90-25 or something like that.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
I have a Holley 750 mounted on a Edel RPM manifold and ordered from Summit P/N HLY-20-95 for $16.95. The bracket mounts directly to the rear carb mount stud.
It does not have provision for Cruise Control though. I called Holley and they do not have such a bracket?????
You mentioned a Button. I'm guessing that your referring to something to attach to the carb linkage for the TV cable tip. My engine is still on the stand and haven't got quite that far yet but yes I will need something eventually for the TV cable tip. I need to replace my entire cable because the end where it attaches to the linkage is broken. Not sure how to solve the Button problem. any ideas?
[This message has been edited by Changa2 (edited July 19, 2001).]
ugh man that sux im sorry to hear that you have to replace that whole cable i think its kind of expensive. i looked through the catalogs and found a button that attaches the t.v. cable to the carb and its like 7 bucks but probably worth it in the long run thanks for the replies guys.
Car: 89 RS
Transmission: TH350
I just recently put a holley intake and carb on my 86 Iroc, and I used all the old brackets and cable. Well I did have to reshape the bracket a little, and adjust the T.V. cable, but it works fine.
I just now found the Holley P/N for the button (they call it a stud). It's #20-40. I'm going to try to find one now, maybe I'll call Summit.
On the other hand, before I pay the S&H (probably more than the part itself) I will check with the local tranny shops.
i dont know about now, but like 3 years ago shipping was free i believe on items that weighed under a certain weight
im in the same boat as you, i need a way to hook up my TV cable to my holley also, thing is i have one of those trannykickdown/ throttle cable universal type brackets but im still short like 4 or 5 inchs from that cable even being close to the linkage on the carb.
ill have to check out that part number you posted.
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
350 cubes
hooker headers
750 vac secondary
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
