What throttle cable works best with a TPI to carb switch?
Old Jul 31, 2001 | 10:12 PM
southerniroc's Avatar
I switched over about 6 months ago and I have found that my throttle blades aren't opening all the way. I am still using the TPI cable but, I had to put spacers behind the gas pedal so they would open up all the way. I tried a 91 TBI cable but it wouldn't work either. What cable can I get, for it to work properly?
87'IROC-Z 357
13.4 @ 103mph(on street tires)
Old Aug 1, 2001 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Any '82-'87 V8 carb cable should work.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 2, 2001 | 01:42 AM
What should I ask them to look up at the parts store? They will want more info. I tried and they acted like there was no such thing
Old Aug 2, 2001 | 02:16 AM
83CrossfireBomb's Avatar
go to the junkyard and take one off a original carb third gen, i got one for 2 bucks, look for the one car that someone dug into under the dash, i found one with the steering column gone so all i had to do was reach in with my hand and snap the cable out without removing any other stuff
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 2, 2001 | 01:53 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by southerniroc:
What should I ask them to look up at the parts store? They will want more info. I tried and they acted like there was no such thing </font>
"Parts store"? I hope you don't mean Pep Boys.
At best, this would be a dealer item. Tell them you need a throttle cable for an '87 305 V8 LG4, VIN "H".
A "used parts" store (okay, junkyard) would probably be a better place, as said above.
Old Aug 2, 2001 | 04:37 PM
Thanks for the info. Maybe I can get everything working like it supposed to be now.
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
