from rochester to edelbrock and...
Old Apr 24, 2002 | 10:09 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
S.O.B. way different, no more hessitation at w.o.t. smooth idle awesome acceleration BUT...
it has cut the mileage to 1/2 (50% less range)
i went from rochester M4MC (vacc sec) to the edelbrock (eldebrok) 1406 (mec sec. 600cfm elect choke).
there's no black smoke, no internal leak, fuel press is stock, new air filter, choke is ok and propperly set.
IS THIS NORMAL?
first time i'm using this kind'a carb and a little advice from the third gen brotherhood will be appreciated with all my heart. thanks to all.
Fernando. :hail:
Old Apr 24, 2002 | 10:32 PM
Jester's Avatar
Just a shot in the dark..but what else did you replace when you swapped over? You did the distributer right?
Old Apr 24, 2002 | 10:40 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
OOOOOPPPPPPSSSSS!!!!!
i did not, but what's the matter? my 350 is totally NON computer controlled, the car is an 87 but the 350 is the old 2pc. rear seal, 4 bolt main block, do you mean i should do the spark advance?
thanks again brother.
Fernando.
Old Apr 25, 2002 | 08:38 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Are you sure it's not because you've got your foot in it alot . I swapped a quadrajunk for a Carter on an old pickup I used to have, and I liked the throttle response so much that I couldn't keep my foot off the pedal!
Old Apr 25, 2002 | 10:00 AM
Jester's Avatar
I thought you were still running a computer controlled dist, and yeah that would do it. if you've already changed it to non-cc version, than nevermind.
Old Apr 25, 2002 | 10:23 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
dont worry bro.
i'm troubleshooting, and cant find anything wrong, maybe its a case of heavy foot and it is normal???
i'll try to lean it a bit, will keep you posted, thanks again guys.
Fernando.
Old Apr 25, 2002 | 03:13 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
guess what!
somebody opened the carb sometime ago (i bought it used) and mixd the jets, so the sec jets were at the prim. place...some guys....
now i need an adaptor to fit it to a spread bore stoch chevy 350 aluminium manifold.
any ideas guys?
by the way... there are no rods on the secondary jets...is that normal???
thanks again.
Fern.
Old Apr 26, 2002 | 01:38 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
there aren't any rods on the secondaries, they're controlled by that air valve over the secondaries...
Old Apr 26, 2002 | 06:00 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
howd you know the jets were in the wrong place?
Old Apr 26, 2002 | 09:11 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
dear pablo and the monkey man.
i've just read the entire section on the basic theory and the tune-up of these carbs (edelbrock website).
now i got it and its done. there's no secondary rods and the sec jets were originally placed right, it was my ignorance on the matter that got it wrong, and more, the choke was not properly adjusted so i did some rigging, so, on test it worked ok but it quit shortly after, that was why i had all that much fuel consumption, i have to order a new electric choke so in the meantime i have it fully open.
really with all the mistakes i have made this carb was awesome compared to the rochester, now after a couple of openings and closings came to realize how simple it is, a true piece of art and now that is properly calibrated IT ROCKS.
thanks to all for your time.
Fernando. :hail:
Old Apr 26, 2002 | 10:35 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i just put the same carb on my car. ad holy crap what a difference i actually noticed my fuel consumption has gone down a bit.it feels like my car it a lot faster.
Old Apr 27, 2002 | 06:35 AM
Blackened's Avatar
I HAD a 750cfm Edelbrock on my 400. It was awesome as far as WOT power and mid range. The thing woudlnt idle for **** and it would almost ALWAYS stall if I stabbed it from a dead stop.
Went to a Holley 750 vac sec. The holley is GREAT around town. Great throtle response, idles pretty damn good, and no hesitation or stall from a stop. BUT, WOT seems A LOT slower
So if your Edelbrock idles and doesnt stumble, KEEP IT !!! lol
Old Apr 27, 2002 | 09:24 AM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
the only time mine stumbles is if i just started it and it hasnt fully warmed up yet. but it works real good when its warmed up. i stomped it from a dead stop, and left about a 30 foot patcg of rubber,from both tires and i dont even have a posi.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
