car dies when you put it in gear help please
Old Aug 5, 2001 | 12:35 PM
hello's Avatar
hi everybody i have a problem i know this is an f-body message board but im helping my friend try to fix up his ford truck he has a ford ranger with an engine out of a ford falcon it has an edelbrock carb on it but im not sure what kind it is but the problem is he can start it but once he puts it in gear the thing dies can anybody help me out im getting pretty stumped on this one thatnks to everyone in advance
Old Aug 5, 2001 | 04:20 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
have him check the timing and idle...
Old Aug 6, 2001 | 01:24 AM
hello's Avatar
ok i'll have him do that anyone else have any good ideas??
Old Aug 6, 2001 | 12:05 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
He probably has a vaccum leak. Also, if it has a large cam, the convertor may be too tight.
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Aug 6, 2001 | 02:09 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Is there any way you could have crossed spark plugs? I wired two cylinders wrong once and it would nearly stall if I gave it just a little gas... I would imagine if this is the problem that you have wired at least 4 cylinders wrong (from dist to cylinder) of course it can only be 2, 4, 6 or 8 cylinders miswired... I would doubt very much so that there is a vacuum leak causing this, but it is always good to check the little things first...
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player
Check out my ride here
Quote from my sister: "It sounds like a boat"
Old Aug 6, 2001 | 10:23 PM
82camaro's Avatar
Car: 82 camaro SC
Usually it indicates a lean condition of some kind(vacuum leak for example. Fatten up the idle mixture and check the idle speed
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 9, 2001 | 09:23 AM
82suped-up-coupe's Avatar
choke the carb slightly with your hand (when warm), if the idle increases you have a vacuum leak.
to easy to check not to
rich
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
