need carb and manifold selection help
Old Aug 9, 2001 | 10:25 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
ok i am getting ready to build my engine, and i still havent decided on a carb or manifold. its a 350HO, 330 hp and 380 ft lbs torque, and i am not sure which carb or manifold to use. edelbrock or holley? whats the difference, pros and cons? what about manifolds? thanks
Old Aug 10, 2001 | 12:48 AM
Jester's Avatar
For a manifold I recommend the Wieand Stealth.
For a carb I say get a Holley 750. Vacuum secondaries if you have an auto tranny, manual secondaries if you have a stick. Don't waste your on an Edelcrap..they suck.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Aug 10, 2001 | 11:41 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I'm with Jester, don't watse your time on Edlebrock stuff. The Wieand Stealth intake would be perfet for your combo. I would say go with a 650 vaccum secondary Holley,but I'm a bit more conservative than the wild man Jester.
Old Aug 10, 2001 | 01:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Jester:
</font>
I totaly agree, the only increase in power from manifolds Ive ever noticed come from wieand products Ie holley.
As far as the 750 holley, it might be better to use a 600 unless your good a tuning and dead set on a DP. Or I have had no problems with the SA "80670" fine carb just loves fuel.
SSC
Old Aug 10, 2001 | 11:09 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Personally, I wouldn't get the weiand stealth. That engine comes with vortec heads and getting that intake to fit would be too much trouble IMO. Otherwise, it's an excellent choice. I would get a performer if you want to keep it stock and an RPM if you're going to change the cam later on. The carb size is a matter of personal preference.
Old Aug 10, 2001 | 11:51 PM
Jester's Avatar
Fbird88 has a point..IF your motor is the crate motor he's thinking of...the one that comes with vortec heads.
If it is your only intake options pretty much are Edelcrock and GMHP I think has one.
JSP Motorsports
ICON Motorsports
Old Aug 11, 2001 | 06:54 PM
i was just about to ask that. GM and Edelbrock are the only people i have seen who make manifolds for vortec heads. i am gonna go with a 600 cfm, as i am not a tuner when it comes to carbs. do they make a stealth in vortec form? thanks guys
Old Aug 13, 2001 | 09:03 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I have had absolutly no problems with Edelbrock... the only thing is the carb is illegal in NY and I can't hook up my charcoal canister... Hp has been upped by about 30 and I don't think the gutted cat can be the sole contributer to this effect... I don't know what you people do to your carbs, but mine runs fine and I don't mess with it...
BTW I would recommend 650 or 700 CFM for a 350
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb & Manifold - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player
Player accessories: fuzzy dice, eight-ball Shift ****
Check out my ride here
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
[This message has been edited by ChillPhatCat (edited August 13, 2001).]
Old Aug 13, 2001 | 11:14 PM
PunXsRock's Avatar
Go with the vortec manifold. It's a bit pricey, but those heads were made to work with that manifold. Go with a holley vacuum-secondary 750 and use Comp Cams XE250H-10. Chevy High Perf used this combo and made an engine that cranked 330 ponies. BUT, it made a whopping 417 lb-ft of torque!!! In my opinion, that's a lot of ****in torque!!! This is what I'm building for my TA.
Manny
84 Trans Am
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
