idle is high.. how do i adjust it?
Old Apr 26, 2002 | 02:45 PM
KiLLJ0Y
Guest
Posts: n/a
i have a 86 305 5 speed with a 4 barrel holley 600cfm, edelbrock performer intake, 180* stat, flex-a-light twin fans... heres the problem
when 1st starts... its idles high as all cars do.. then drops to normal idle of 700 rpms.. when i start driving around and come to a light and i shift to neutral.. it idles up to 2200 rmps and wont come down from that... the holley is an electric choke, vacum secondary... it also appears the car is eating alot of gas...
what can i do to help this???
Dave Fisher
Orange CA
Old Apr 26, 2002 | 06:36 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
i've had the same problem on my cc-q-jet i sprayed some PB Blaster on all the cables and linkages and that worked for me
Old Apr 26, 2002 | 06:56 PM
bills82z28's Avatar
Get rid of the holley & get a edelbrock.
Old Apr 26, 2002 | 07:51 PM
KiLLJ0Y
Guest
Posts: n/a
to the last post..
yeah too bad money is an issue and i highly doubt that the whole carb is the problem... i just had it re-built professionally.. so.. yeah.... my guess is that the positive wire has some how lost power... im going to try and run a wire from the battery with an inline 30amp fuse to the positive on the choke.. and hope that solves the problem...
PS.... edelbrock is what i replaced... those things arent worth the metal they are made of..
Old Apr 26, 2002 | 09:25 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
30a. is way too much fuse for that application bro, i suggest that 10a. is far enough, and on my 350 i just tapped an extension from the power wire that goes to the distributor straight to the electric choke, just keeping in mind to have it propperly isolated from heat and possible chafing, thats it.
good luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
