Auto Choke Light Staying On
Old Aug 17, 2001 | 12:34 PM
modeman's Avatar
Hi,can anybody out there tell me why my Auto Choke Light stays on and the Choke continues to operate/engine races even though the engine as reached operating temp? Also, my Temp Gauge is not working, are these two problems connected? The car is an 1985 5.0 Iroc. Thanks in anticipation.
Old Aug 17, 2001 | 10:41 PM
82camaro's Avatar
Car: 82 camaro SC
Check the alternator, when the alternator stops charging the choke light comes on--cool huh. Since the temp guage isn't working, it's possible to have a bad wire, bad connection, or something in the wiring that is not working.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 18, 2001 | 02:52 AM
modeman's Avatar
Thanks for that, the alternator has stopped charging, wil be getting a re-build asap,will be checking the wiring to the Temp Sender right now
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
