Engine Running On
Old Aug 18, 2001 | 11:21 AM
quattroboy's Avatar
Engine Running On
Help - Anybody out there know why my engine is running on for a few seconds after I switch off? I think that the choke is still on because the revs are more than 1500/1750 and the infamous choke dash light stays on but I also know that my alternator is dead, soon to be rebuilt/replaced. Will the running on and high revs be connected to my dead alternator?The car isn't being used until I sort out the alternator but I am hoping that the running on/high revs/choke still operating(?)will be cured with the fitting of a replacement alternator. Any info/ideas gratefully received. 1985 Iroc 305 4bbl Auto.
Old Aug 18, 2001 | 04:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It could be related to the alternator. After you get that fixed, check the voltage to the choke with the engine running. You should have about the same voltage as you have at the battery. If low, check the wiring and the choke relay.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
