distributor question
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
okay i am swapping to carb from tbi i have purchased the accel performance replacment distributor with HEI. what else do i need to buy to make this distributor work. one the top i see coil terminal and coming out of the side is a three wire(red,brown, and black wires) harness with a connector on the end. what do i need to do to make this thing work if anything?
thanks
brady
thanks
brady
also will the distributor gear work with my roller cam?
the distributor is accel part number 59107
i was looking at getting an accel HEI super coil either the 140003 or the 140005 one is for red and yellow wires the other is for red and white wires. which do i need? i really need some help with this.
thanks
brady
thanks
brady
Transmission: 4L80E/4L80E
The three-wire connector goes to the cap. The pickup gets power and operates the coil through that harness.
The distributor needs ignition-switched power to the "Bat" terminal at the cap, and the coil wire to the "Tach" terminal right beside it. Pretty simple, really.
The wire colors you're asking about are the igniton module wires in the base of the distributor. Look at what it's got, make the selection based on that.
) where does the Bat wire go? where does the tach wire go? ok i am switching TBI to carb so right now i dont have an ignition module do i? just a bunch of wires that go to the remote coil. please help me out as i am
The coil p/n's you quote are HEI in-cap units. When you install one of them into the cap, terminals stick down so that the 3-wire connector from the distributor base and the ignition and tach wires come in from the bottom of the part of the cap that sticks out (have you gotten a cap yet?).
Hmmm, I'm assuming too much. Since HEI has been around since 1974, I assume everybody's seen one. Sorry. Those markings are on the coil cover, or the coil if you get one of those Accel units.
thanks
between your advide and me going over to a friends house to check out his car i think i have it figured out. i dont have the coil yet but i do have the distributor and cap. i need to get a coil and put the the 3 wire connetor into the coil. then right where i plug the 3 wire connector into i need to plug two wires into the coil i an assuming the red and white wires. the red is a power wire and the white or yellow goes to the tach? am i right?
thanks
brady
thanks
brady
They'll be the same wires currently used for power and tach. I haven't have much exposure to TBI, but what you said sounds right.
