Need some help with non CC Quadrajet
Old Aug 19, 2001 | 05:46 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I put the new motor in my firebird and replaced the computer controlled Q-jet with a non-computer controlled Q-jet. I have some of the vacume lines hooked up, and some that aren't. The ones that I didnt know where they went, I plugged. The motor wont run right and I'm wondering if because I may have plugged some of the wrong lines is the cause. Are there any diagrams or pictures that could show me where these lines go? I've searched and found that there are diagrams on the hood and fan shroud. I dont have those though. Any help would be greatly appreciated! Thanks.
Old Aug 20, 2001 | 08:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There really isn't that much to do. You need the large one in the front center to go to the PCV valve. The large one in back goes to the power brake booster. Then, the smaller one on the driver's side front corner to the vacuum advance (you do have a mechanical/vacuum advance distributor, right?).
Assuming you don't have a snorkel-type air cleaner and aren't worrying about the charcoal canister.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 20, 2001 | 04:54 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I have all the necessary ones, that you talked about hooked up. Something is still not right though. I dont know if its the carburetor or not. (It keeps flooding and now wont even fire. ). I'll have to go through and check it out I guess.
Infested
May 22, 2018 11:56 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Thaney9
Aug 29, 2015 03:16 PM
