idle problems....need help
Old Aug 21, 2001 | 06:03 PM
brian86Z's Avatar
i have a carbed 383 with a holley 750DP on it. i am having a problem with the idle not coming all the way down to the proper idle speed once motor gets warmed up. when i come to a stop sign and push in the clutch the idle just hangs at the cruising speed or drops a little and then hangs. if i let out the clutch a little to bog the motor down, the idle comes down to where it should be and its is fine. i can not find any vacume leaks anywhere, and the mechanical choke does not seem to be sticking or causing problems.
i also checked with the distributor. i had a problem with other motors where if i had the lightest springs on for the mechanical advance that it would not pull the weights back in sometimes. i tried heavier springs but i still have the problem.
any ideas for me?
Brian
Old Aug 22, 2001 | 03:20 AM
83CrossfireBomb's Avatar
i had a 750 edelbrock in my nova, bought it brand new, not too long after i put it on, it would do what you described, i just tapped the throttle with my toe and the idle would go down, had to do it everytime i let my foot off the gas. the problem i had was the butterflies would stick because they had gotten a bit crusty, i cleaned them out and the problem went away.
just a thought
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
