Dom spacer plates actually work?
Old Aug 22, 2001 | 08:24 AM
firebird305's Avatar
Before i got my carter carb,i had a spacer/adopter plate to run the q-jet carb i had on my performer r.p.m.intake. i've had some people tell me that since i have a square bore carbeurator now i can take the spacer plate,Flip it upside down and put it between the carb and the intake and gain a little more power at the top end.Has anyone ever tried this and does it work? The spacer plate is about 1 inch thick.I've seen the spacer plates in summit/jegs that are suposed to give you more power,Does anyone knows if these work? And the name of this post is actually do spacer plates actually work (stupid keyboard!)
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
[This message has been edited by firebird305 (edited August 22, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
kah992
Aug 19, 2015 02:55 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
