clicking noise from choke
Carb is from 1984 L-69. When I turn the key to the on position, the choke(I think its the choke anyway) starts making a real rapid clicking sound. Also, the choke does not seem to be "compressing" for lack of a better word, in preparation to start the engine. Has anyone ever had a problem like this before? Thanks in advance.
Transmission: 4L80E/4L80E
The clicking is actually the mixture control solenoid. If you don't start the engine after putting the switch to "on", it should stop clicking after about half a minute.
In order for the choke to close, the engine has to be cool, and the throttle opened slightly.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited August 21, 2001).]
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
my car does the same thing it is normal. dont worry about it
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Car: 1986 Firebird
Engine: LG4 305
I had the same clicking question. Thanks for the post. I've still got one problem though. When I first start the car in the morning, the choke doesn't close. The car sputters and dies, and as it dies the choke closes. When I restart it, the choke opens again, and the engine usually hangs on, although it runs poorly until the temp gets up. What is the choke doing?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You kick the throttle before you try to start it? Sounds like the choke linkage or shaft is sticking and needs to be cleaned.
Car: 1986 Firebird
Engine: LG4 305
Yeah, I give the pedal a stab to the floor before I start it, but the choke doesn't close. But as the car sputters out and dies, it slowly closes just like it should. Then when I restart it, the darn thing opens right up again. So if it was sticking, it shouldn't open and close at all right?
Engine: 383 Carb
Transmission: 4L60
It could do what your describing. You might free it up by hosing it down with spray carb cleaner, or you might have to rebuild.
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
