Wierd Idle Problems Please help
Old Aug 24, 2001 | 03:38 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
When i start my firebird in the morning (when its cold) it'll idle fine for a second. Once i drive it, or give it a little gas, the idle will go way up (1500-1800 rpms) and stay there for a moment and it will smoke a little as well. The smoke is definately unburned fuel, not burning oil. Is my choke messed up? I tend to think so because this doesn't happen later in the day when the engine isn't cold. When the engine is warmed up the fuel smoke goes away and the idle goes back down to around 900-1200 rpms the rest of the time, which is still high. What could be causing this high idle?
Red '87Formula Firebird
-mostly stock 5.0L LG4 w/cowl induction setup borrowed from '83 TA and T5 tranny.
How i do at the stop light:
ricers: 3-1
rustangs: 1-too many
Old Aug 24, 2001 | 01:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sounds like the choke. You might check all the linkage to see if somthing is binding. Its possible that when you start the car the choke isnt set and when you actualy put it in gear and step on the gas the choke is setting itself because he engine is still a bit cold.
SSC
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
