What size carb should I use?
Old Apr 29, 2002 | 03:08 PM
mefreema's Avatar
I have a sbc 355 dart 200cc runner 72cc combustion chamber. Comp Cam Magnum 276 cam, edelbrock performer intake, full length duels with H pipe. TH350 trans stock converter for now with 3.55:1 gears in a 79 vette. What size carb would be good? I have my eye on a Holley 750 on ebay, would that be too big?
Old Apr 29, 2002 | 06:14 PM
82camaro's Avatar
Car: 82 camaro SC
750 should work just fine.
Old May 4, 2002 | 06:17 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
750 Holleys are nice, I have one my self. Just learn how to tune it!! With the set up you have yes, you should be fine. You still might run a little rich though.
Old May 4, 2002 | 06:33 AM
DABE's Avatar
my setup is basically the same minus heads....i have a 750 double pumper and it uns richer than Bill Gates....ive jetted it and all and its still rich...
Im going with a 625 Edelbrock, (neighbor works for Edelbrock!)
He said ill gain hp from the swap...i was like score...he said that the 750 is still much carb for a 350...
CFM= cubes (355) X max engine RPM X .9(Volumetric Eficiency (90% for performer intake) / 3456
VE for the performer is 75-90%
IF VE is less than 100% the amount and quality of charge in the cylinder is reduced so less torque is produced. VE is above 100% is a supercharging effect and more torque is produced.
Get this?....i took it STRAIGHT out of a Edelbrock 2002 catalog...just plug in the max RPM and that will tell you the CFM needed....
Hope this Helps..
DABE
Old May 4, 2002 | 09:41 AM
Jester's Avatar
A 750 Holley should be perfect.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
