holley gurus
Old Aug 20, 2001 | 04:08 AM
Federico's Avatar
holley gurus
The throttles blades of my carb.(600cfm vac.sec.)are not completely opened(SLIGHTLY ANGLED). WHAT SHOULD I DO TO CORRECT THE PROBLEM?
Old Aug 20, 2001 | 08:25 AM
82camaro's Avatar
Car: 82 camaro SC
Primaries and/or secondaries? Are they over center, or not to the center? You may just need to adjust the throttle linkage.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 20, 2001 | 11:38 AM
Federico's Avatar
the primaries and secondaries remains slghly angled of the same angle about 10/15°
Old Aug 21, 2001 | 04:39 AM
Federico's Avatar
Hey There's some one here yhet can give me some suggestion!!!!
Old Aug 22, 2001 | 02:44 PM
Biochem's Avatar
Car: 2002 SOM z28
That is pretty much the way they should be... if they were flat (0 degrees) then the primary would not expose the transition slot. The more important question than "how to fix it" would be how does it run when they are the way they are?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Aug 22, 2001 | 03:03 PM
Federico's Avatar
When i'm cruising at about 50/60 mph 3RD GEAR,i smash the pedal to the floor(2nd gear) my car as NO POWER from 2,000 to 3,200/3,500 ,after that, power start to come out.
Another thing: when i'm accelerate from standing position i heard backfiring coming from the carb and/or the engine bogs.
I THINK THAT MY CARB NEEDS TO BE TUNED UP ,i've alredy checked the acc. pump and it's fine WHAT OTHER THINGS I NEED TO CHECK?
Old Aug 22, 2001 | 05:10 PM
evil t/a's Avatar
Your timing is retarded. Advance it.
Old Aug 23, 2001 | 02:54 AM
Federico's Avatar
OK Do you think that FULL ADVANCE AT 2800 RPM SHUOLD BE OK?
Old Aug 23, 2001 | 03:00 PM
Biochem's Avatar
Car: 2002 SOM z28
No, I think what Evil t/a means is that you have to re-adjust the base timing (disconnect the vacuum advance while you do this) to about 8-10 degrees... and tighten your distributor hold-down screw too!
Old Aug 23, 2001 | 07:34 PM
Z28fromItaly's Avatar
All third gen camaro has the elecronic distributor. Did you swap it with a vacuum one?
Old Aug 24, 2001 | 08:18 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
Sounds like your Accelorator pump isn't giving you enough gas when you stomp it. The lean backfire you stated before is the flag for that. Try getting a different pump cam.
[This message has been edited by Chvywolf (edited August 24, 2001).]
Old Aug 25, 2001 | 05:20 AM
Federico's Avatar
I think that the accelerator pump is OK 'cause my problem begun after my car has passed the emission test here in Italy,before that my Z was very fast,i don't know why?
The mechanic has adjusted something, i guess.
NOW I'DONT KNOW WHERE TO START TO FIX UP MY Z28 .
ANY SUGGESTION IS REALY,REALY,REALY APPRECIATED!
Ciao Z28fromItlay!
Old Aug 25, 2001 | 08:22 AM
What about the fuel pump?
Anyway if a italian mechanic put his hands on your car chance are he messed up something in the emission sistem or somewhere else, becouse they usually don't know nothing about our cars. I use to do all the job by myself, that is the only way to go if you want to keep your car running great.
Write me at mefist99@hotmail.com
Old Aug 25, 2001 | 11:44 AM
evil t/a's Avatar
you mechanic retarded your timing , advance it to about 10 degrees and see what happens.
Old Aug 25, 2001 | 11:46 AM
Federico's Avatar
I've just checked my float levels :no fuel coming out the sight plug ,no fuel at all just AIR!
Old Aug 25, 2001 | 02:19 PM
evil t/a's Avatar
Shake the car and see what happens
Old Aug 25, 2001 | 02:26 PM
Federico's Avatar
Shaked by a football player ,nothing,just AIR
thank you anyway.
Old Aug 25, 2001 | 11:21 PM
evil t/a's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Federico:
thank you anyway.
</font>
Then set your float a little higher until it just starts dribbling out. And whats with the "thank you anyway" stuff?
Old Aug 26, 2001 | 12:56 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
If possible, hook up a vacume guage and an Air/Fuel ratio guage to it and see what it's doing. I'll bet 5$ that it's going lean when you punch it. Do you know what color spring you have for the Vac sec?
Old Aug 26, 2001 | 02:26 PM
Federico's Avatar
The spring is plain steel ,the accelerator pump is the black one.
Old Aug 26, 2001 | 02:59 PM
Federico's Avatar
I've forgotten to say that my car has a strange mileage : about 22 MPG.
Old Aug 26, 2001 | 10:05 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
That pump cam may be too small. Try using the orange or yellow (i think it's yellow) The lob is a bit more agressive
Old Aug 30, 2001 | 12:07 PM
Federico's Avatar
OK this is what i did, waiting for the engine to warm up (175°) recarb my holley ,set the base timing to 8 ,set a good float level.
Now the car is fast as it should be ,but when i start from a standing position power comes out too far about 2,800rpm before that i don't feel the power that it should have,but after 2,700/2,800 is very strong.
This what i do to launch my car :1st gear (not D ),I keep one feet on the brake untill the engine reach 1,800 rpm then i release the breke .
AM I DOING WRONG?
I 've a 3 speed trans (350 i think)
Old Aug 31, 2001 | 01:39 PM
Federico's Avatar
Anyone?
Old Aug 31, 2001 | 02:39 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
Do you have a differant Stall converter? I know at 1500 for mine, the tires are spinning
As far as power below 2500, i can't tell you without knowing the vacume and A/F ratio. Sorry
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
