Non CC Qjets and HEI
Old Sep 9, 2001 | 07:24 PM
Marc 85Z28's Avatar
What model and years of vehicles have the best non cc qjets and HEI distributors for a high performance rebuild on a 400HP 350?
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, built 700r4 w/Darrell Young 2400 stall TC, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Sep 9, 2001 | 08:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Since your going to be putting up some impressive HP I would suggest looking for a BBC with all the goodies intact. The reason being most BBC's have healthy rods/jets in them already. But any 73-80/81, distributor will work fine. But then any 73-81 carb should be fine to start with.
SSC
Old Sep 10, 2001 | 12:01 PM
Duane K's Avatar
I would look for a carb and distributor from an L82 'vette. The L82 cam had a 450/460 lift and appropriate duration and as a result the advance curve and off idle jetting would be closer to what you will need.
Many years ago I built a 350/327 for my chevelle. It was a real dog until I got the right carb and distributor. I tried a BBC q-jet and while it worked great wide open it just never drove that well. I changed jets, metering rods and power springs but finally gave up. I think the of idle circuit just couldn't be modified enough to handle a smaller engine. I got a rebuilt carb and distributor with the right codes and with a bit of tuning got it to where I wanted it.
Good luck & cheers,
Duane
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
