600 or 750 CFM carb?
Old Sep 17, 2001 | 08:40 AM
RayZeR14u's Avatar
I just recently put in a new recon 4-bolt main 350 in my third gen. I replaced the cam with a 280/465 cam and plan on headers pipes. I need a new carb and am not sure if should go with a 750 or 600. Is a 750 too much carb for my engine? I don't really plan on any other mods to the engine except maybe a different intake with the new carb. Thanks in advance for any help.
[This message has been edited by RayZeR14u (edited September 17, 2001).]
Old Sep 17, 2001 | 04:54 PM
Jester's Avatar
750 would be just fine.
Old Sep 17, 2001 | 06:41 PM
RayZeR14u's Avatar
Thanks Jester, you the man!!
Old Sep 17, 2001 | 10:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Jester, you must be 750 happy!
A 750 would be fine if you live in fairly low altitude, if you can get to an ocean in less than a day or you dont live in the mountains a 750 is fine. If you get a holley I would suggest replacing the power valve with 6.5 PV and recalibrating the secondaries to open slower.
With your mods and a 600 cfm would work great also in factory from.
Good luck!
SSC
Old Sep 20, 2001 | 01:33 PM
82camaro's Avatar
Car: 82 camaro SC
If it's stock except for the cam change, 600 cfm is plenty big.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sreZ28
Oct 22, 2015 08:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
