M4ME
Old Oct 15, 2001 | 12:28 AM
jag's Avatar
jag
M4ME
I understand this is a 795cfm carb. I would like to modify it to give me a little more gas. I was told to change the metering rods out and that something needed to be ground down to allow the secondaries to open? Any help would be appreciated. I have a Performer carb, but I was told I needed to keep my Q-Jet's TPS for lockup, etc.. (I don't want to lose lockup, or have to do it manually or unreliably. I like it computer controlled.)
Old Oct 15, 2001 | 09:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out the tech articles on this board. There's an article there about getting what you want out of your q-jet.
It will only be 795 cfm if your secondary air valves are opening up all the way. The tech article will guide you to determining that.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
The Eager Teen
Feb 15, 2014 03:11 AM
Austin19
Carburetors
Aug 21, 2012 10:18 PM
bluedevilinaz
Carburetors
Jan 21, 2012 03:04 PM
ROFLsplash
Carburetors
May 17, 2010 11:34 AM
OS3Fleming
Carburetors
Jul 3, 2007 04:00 AM
