CCQ-jet - will it run without the ECM?
Can I put a non ECM controlled HEI on an LG4 and still use the CCQ-jet? I am going to take the engine off computer control but will keep the Q-jet on it if it still runs. Otherwise I will put a Holley on it. WDYR?
Transmission: 4L80E/4L80E
Run? Yes.
Run properly? Absolutely not.
Why would you consider this? There is nothing about the CC HEI weaknesses that a non-CC HEI would cure. Everything you have to do to a CC would have to be done to a non-CC, and vice-versa.
And, going Holley would require another intake manifold or an adapter - the former isn't necessarily a bad idea, the latter is. Plus, your SES light will come on and stay on, and if you have an automatic, your lock-up torque converter function would have to be re-engineered. To say nothing about a pretty good chance that your gas mileage will go down.
Also, consider the fact that for less money than it would take to get a non-CC HEI and carb going, you could make the CC system sing.
I think you should reconsider your course in its entirety.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 82 camaro SC
If you get rid of any part of the computer system, you need to remove it all. You really need a combination of parts to gain much power. A holley carb and non computer HEI might help a small amount. However, if you add an aluminum performance intake (action plus for example) and a better cam(around 268 duration) with a holley carb and non computer HEI you will pick up some power. Next would be heads. Also, headers will free up some power as well. But if you only want to replace the carb and distributer, you may want to take five7's advice above.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
<font face="Verdana, Arial" size="2">Originally posted by PerthZ28:
Sing?? How? How do you get around the lame advance curve?</font>
Actually, the factory advance isn't all that bad. If you're talking about what you get when you set the timing, that's the limp-home mode, and is lame. The ECM controlled advance usually just needs some more base advance to get it going.
[This message has been edited by five7kid (edited October 11, 2001).]
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
For the least work, go to the junk yard for a non CC distributer... then buy a non-CC Qjet (# 70XXXX or 1705XXX) off ebay for $25 and rebuild it for $20...
I can't endorse that. If the CC system is working (i.e., nothing is broken or missing), then the simplist thing is to keep the CC working. Ignition upgrades (which you should do with a non-CC HEI anyway), ignition timing advance, and secondary tuning will be less hassle and less money than going non-CC.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I agree with Five7Kid The easiest thing would be to keep the computer, but it wouldn't take too much money at least to switch over... depending on the carb you plan to run (need a spread bore adapter or new manifold).
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
I can't endorse that. If the CC system is working (i.e., nothing is broken or missing), then the simplist thing is to keep the CC working. Ignition upgrades (which you should do with a non-CC HEI anyway), ignition timing advance, and secondary tuning will be less hassle and less money than going non-CC.</font>
Car: 84 T/A
Engine: 305HOL69
...and if the ECM is still happy to control the carb...</font>
<font face="Verdana, Arial" size="2">A non CC HEI with the E4MC seems the ideal solution to me. WDYR?</font>
I was toying with the idea of adding a CC module and 4-wire harness to a vac advance distributor but have been working too much to try and apply the idea. (Someone else wanna try it for me?
D.R. Stevens
1984 Trans Am 305HO L69
all the usual external/free mods, original engine
1991 Firebird 305 L03
2 free mods and a K&N,
otherwise stock
Thanks for that 84. That's just the info I needed. Did you ever replace the carb and get it to run without the ECM? If so, how was it?
[This message has been edited by PerthZ28 (edited October 16, 2001).]
