OK guys, whats the LOWEST profile edelbrock manifold
Old Oct 4, 2001 | 08:47 PM
qazd's Avatar
I need to know the lowest profile (edelbrock prefered)so I can close my hood and not crush my airfilter. It hits because i have to use the conversion plate from spread to square bore. I need to buy a square bore intake that will keep my carb as low as possible.
'87 Z-28 305,Edelbrock 600 cfm, stock 700-r4 terribly slow
Old Oct 4, 2001 | 11:07 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I believe the Performer (not RPM) Intake is their lowest profile... you definitely want to lose the adapter. I've got a performer it gives me 2" clearance at the closest point with the Pro-flo filter... the power bulge hood shows the clearance.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb + Intake - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, AIWA bargain basement (from Sears of course) CD player, Eight-ball shift ****
Check out my ride here - My $1300 Toy
"IT'S SNOWING! TO THE HIGH SCHOOL PARKING LOT!" - The Mustang and Firebird face off in the dead of winter.
Old Oct 4, 2001 | 11:10 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Oh yeah... just to give you comparison, the Pro-flo filter stands 3" high... so a 14x3 filter should still clear.
Old Oct 5, 2001 | 10:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
14x3drop base with 1/2 inch spacer on a stock "GM" manifold and the standard adaptor plate fits fine and is about 1/4 of an inch taller than edelbrock performer or wieand action+ manifolds. Although I dont reccomend using a stock replacement type manifold like performer or action+ because they really arent much better than stock ones. You might want to look into a steath they seem to fit everyones cars but mine and are much better than edelbrocks selection.
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"Web site under construction"
G0D Bless.
Old Oct 5, 2001 | 11:28 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I would say the performer is much better... HAVE YOU LOOKED at the stock manifold versus the edelbrock? There is a big difference in flow... I bet the edelbrock is good for a 305 up to 300 Hp... Isn't stealth kinda pricey compared? If you're looking to build a 350 or something bigger then yeah, you should probably buy a stealth... but sticking with a 305, the performer will suit you just fine.
[This message has been edited by ChillPhatCat (edited October 05, 2001).]
Old Oct 6, 2001 | 01:21 AM
fast_broker's Avatar
You can get 350hp with a 350cid with a Performer. Plenty big enough for a 305 IMO. That guy is right, the runners are quite a bit larger than OEM.
For PURE top-end/high-rpm only, use the RPM.
Old Oct 15, 2001 | 10:00 AM
speedfreaker's Avatar
dont get the performer rpm!!!! i have one needed an adaptor plate and i still cant fit it under my cowl hood i had to modify
Old Oct 15, 2001 | 01:44 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Although I haven't looked at a performer RPM specifically, I would imagine you don't need an adapter plate to put an edelbrock carb on an edelbrock manifold... The plain performer is very versitile though I do highly recommend it.
Old Oct 21, 2001 | 01:40 AM
MaximumRacin's Avatar
i got a rpm. 1 in spacer.650 double pump holly. and a edelbrock airclear this all cleared my hood. and i have a 2 1\2 in daytona hood.only thing touching is the dam air cleaner stud. i need to cut that 1 day
Old Oct 21, 2001 | 12:41 PM
E-Z Rollin's Avatar
I read an article on Holley,Edelbrock,and Weiand low rise manifolds,the Weiand out performed the others but I don't know if it's
low enough to clear your hood[8004 or egr model]. Before I start an riff remember I said low riser,not the rpm or stealth.
customblackbird
Aug 15, 2021 10:16 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
