What carb's offer better reliability than the holley's?
I've had nothing but problems with these holley carb's. At first, a mechanic and the owner's of the speedshop couldn't get my first THREE holley 650 double pumper's (#4777) to maintain proper fuel lvl's in the bowls, my 4th one was fine at first, but Im always' worried about going anywhere more than 20 min away cause my carb still seems to act up and cause me to coast to a parking lot, or side of the road, and screw around with it so it will start back up again. So, Im figuring screw the holley's and the performance they give, and getting a carb that's reliable.
What's out there that can still make a mid 13sec car perform, and give me some piece of mind that my car will make a trip to the track (that's an hour away) and back home again?
After getting stuck today with my new engine and car for an hour, I'm completely sure that I've had enough of the holley's BS. My car run's mid 13's, why the hell should I have to treat it as a drag car that isn't a daily driver?
Please give me some suggestions, I'll sacrifice performance as long as the car will run well.
Thanks,
Scott
I also have another post about the floats and what happened today, I've still gotta get that pos working till I can afford another carb.
Thanks,
Scott
You got DIRT, S**T or something in the gas tank. Gona have to pull it and clean it out. Power flush the fuel lines and pump.
REPLACE the fuel filter, NEEDLE and SEATS
and Powervalve. What pump are you running?
The holley "blue" electric pump will give you nothing but trouble. (pressure creep thru
the regulator at idle) It wasn't designed for street use. I'd get a hi flow Mechanical 6 to 9 psi pump . (Edelbrock, Holley, Barry Grant.) It has more than enough flow and just enough pressure for your motor.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Holley carbs are reliable. Most of the problems people have will holleys turn out to be lack of tuning.
383 86 Camaro Z28 ---1/4 mile e.t>12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
[This message has been edited by Big454blockchevy (edited October 23, 2001).]
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I know both og the Holley's I have/had work great. The first was bran new, the second, that I am using now was used. I would agree on the lack of tuning. If you think about it, there are about a million different combos to tinker with. Pump cams, squirters, primary-secondary jetting, power valves, acc.pumps, and if you want to get creative, you could adjust the air bleeds. On some Demon carbs you can change out the boosters too. Holley is known for performance, but the price is tuning to your set up.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Joshua Johnston
1991 Z-28
Car: 1983 Z28
Transmission: WCT5
<font face="Verdana, Arial" size="2">Originally posted by Surreal86z:
What carb's offer better reliability than the holley's? </font>
They can support way more car than you've got.
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
