who changed a TPI to Carb?
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
When you change a TPI to a carb is it as easy as just taking off the TPI set up and putting a manifold and carb on? What can you still use and what do you have to take off. I would like to be able to put a TPI back on just in case I move to a state with strict emissions laws. I can put a tpi on for the test and when it passes put the carb back on.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I switched mine from TPI to carb. Its not as easy as pulling the TPI stuff off, and putting carb stuff on. At least it wan't for me. I pulled my computer and the harness out of the car. This meant, I had to redo my fans, and fuel relays. While reworking my fuel relay, I decided to skip the oil pressure switch, and put in a mech. gauge. I would imagine if you kept the computer, and harness in the car, you could switch back fairly easy, once you got it to run with the carb. I did mine with the thought I would not be going back. Someone else here might know more about what is needed.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Joshua Johnston
1991 Z-28
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
