Have to "blip" throttle constantly to drop idle...
Old Nov 7, 2001 | 08:30 AM
scauffiel's Avatar
It's a vacuum secondary'd Holley 750 on a 383 in my '88 TA. I went from a 305 TBI to this, so I'm not real familiar with carbs.
Basically I have to blip the throttle whenever I come to a stop, or just slow down to drop the rpms below 1500. It usually just takes a single tap to do it, though sometimes it takes several. This happens when the engine is warm as well as cold.
I searched through some posts and am going to try some cleaner in the bores in case the blades are stuck on some gunk, but other than that I have no idea. I thought my tranny cable may be too tight and holding it open, but it's fairly slack.
Any ideas are appreciated! (And because I'm new to this carb thingy, the more detailed the better! )
Steve
Steve's Trans Am Temple
Old Nov 7, 2001 | 09:56 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Sounds like the choke is going whacky on you... see that it's hooked up properly and try that carb cleaner... it's probably just gunked up.
Old Nov 7, 2001 | 10:56 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Install a throttle return spring on the lower part of the throttle linkage and anchor it back on the detent cable bracket.
There is an angled tab with a hole on the bottom of the linkage just for this. Make sure the spring is parallel to the throttle cable and has enough tension.
Old Nov 8, 2001 | 12:07 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Um, FYI, if you are having choke problems, this WILL affect your mileage
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
