i just recently changed over to carb
from tbi. when i turn car off now , it does not turn off immediately. it runs for about 30 seconds after switch is turned off then slowly dies. it is not "running on" it is like the switch is not turned off. what could cause this?
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It could also mean your distributor is advanced too far. Retard it a few degrees and see if that stops it.
I'm not sure what, but you must have screwed up something in the wiring. Check the wire going to the batt terminal on the distributer, I'll bet you it's hot even when the key is turned off. It shouldn't be. Check that and trace the problem from there.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I HAD THIS EXACT SAME PROBLEM! When I converted to carb I wired my cooling fans directly to the ignition. Everytime I'd turn my car off the fan motors would generate power and feed it back to the ignition. The power would slowly dim out as the cooling fan motor came to a stop and the car would die.
Hook anything that could be doing that up to relays.
