Removing EGR, need help
Old Nov 22, 2001 | 10:51 AM
Matt86t/a's Avatar
I am taking the egr and my stock q-jet out of my 86 t/a. It is the LG4 engine, and I will probably get the Demon 600cfm carb for it. What do i need to do in order for the new carb to work, and what do i need to keep in terms of all those damn hoses on my valve covers? Thanks a lot.
86 T/A, 305 V8; hey, I'm workin' on it
Old Nov 22, 2001 | 01:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1st, I don't think you'll see much improvement if any over simply working with your q-jet. It'll cost you a lot more money to do what you're suggesting, that's for sure.
But, to make the Demon work, you need to get a non-CC vacuum/mechanical advance distributor since the computer won't control the distributor properly without the CC carb.
The hoses to the valve cover are associated with the PCV system, not the EGR. So, you need to keep the one with the PCV valve that goes to the driver's side cover to the carb base, and at least put a breather cap in the one on the passenger side cover.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited November 22, 2001).]
Old Nov 22, 2001 | 01:49 PM
five7kid's Avatar
Oh, you'll probably need a carb adapter or replace the intake manifold to get the Demon to mount as well.
Old Nov 30, 2001 | 11:09 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
isnt removing egr illegall i heard its a 2500 dollar fine. o well
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
