Jet performance quadrajet
Old Dec 1, 2001 | 09:03 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Has anyone else seen these carbs in the summit catalogs? Theres three different stages and they are direct replacements, 50 state smog legal. They were no more then 400 dollars a piece, wouldnt that be a good idea to buy then to have the old tired qjet rebuilt? im thinking of getting the stage 2, can anyone fill me in on these carbs? thanks
Old Dec 2, 2001 | 12:27 AM
MotorCityMuscle's Avatar
I hear they're quite good. Two years ago Hot Rod had a guy building an 83 Trans Am with a 385 stroker and one of those carbs. He said it ran great. Also, Car Craft(I think) used a non CC version on a Buick engine and said it was the best Q-jet they'd ever run. Id buy one if I needed a carb.
Old Dec 2, 2001 | 01:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Careful. They are NOT CC carbs.
You can send your carb to Jet and have them do a Stage 2 on it. They'll fix whatever is making yours tired and old. Takes about a week from what they told me (haven't done it, though).
The Hot Rod articles to which Muscle refers are on this board in the magazine articles link. By Steve Green, called "Stroke in the Desert". Good reading.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 3, 2001 | 01:28 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by MotorCityMuscle:
Also, Car Craft(I think) used a non CC version on a Buick engine and said it was the best Q-jet they'd ever run. Id buy one if I needed a carb.</font>
They went from something like 12 mpg to 17, too. You gotta like that!
Old Dec 5, 2001 | 10:44 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
When my current 383 was at the planning stages I thought about going with a jet performance q-jet but decided to go with a Holley carb instead. Also my main reason for not going with a CC q-jet was it would not be able to quench the thirst of a motor making above 400HP.
383 86 Camaro Z28 ---1/4 mile e.t>12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
[This message has been edited by Big454blockchevy (edited December 05, 2001).]
Old Dec 5, 2001 | 10:48 PM
Car: 86 z28
What are your mods and what are your future plans (if any)for your engine?
Old Dec 6, 2001 | 04:01 AM
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by Big454blockchevy:
</font>
I don't know about the cc Qjet, but any 750cfm carb can handle 400 hp, with ease.
Old Dec 6, 2001 | 07:14 PM
Car: 86 z28
<font face="Verdana, Arial" size="2">Originally posted by Sitting Bull:
I don't know about the cc Qjet, but any 750cfm carb can handle 400 hp, with ease.</font>
Not just any 750cfm carb would do the trick it would actually have to be tuned for the specific engine . I have seen 750 cfm carbs not even able to handle 300Hp because lack of tuning!
383 86 Camaro Z28 ---1/4 mile e.t&gt;12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc&gt;2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
