ac solenoid
Old May 15, 2002 | 01:34 PM
Chevy83Z28's Avatar
ac solenoid
hey guys, I pulled the whole a/c assembly off my lg4 a while ago and yesterday I decided to pull the a/c solenoid off the driver's side of the carb (the solenoid recieves 12V when the a/c and defroster are on, and it pushes a rod out that bumps up the idle speed a bit higher than idle.) I took it out because with 12V applied to the solenoid, the arm wasn't even pushing out enough to touch the throttle linkage and since there's no a/c, the piece is rather pointless and makes it harder to adjust the idle screw.
My question is this, now everytime I shut the car off I can hear a relay under the drivers side dash making noise. If I hook the solenoid back up the noise goes away, so it's definitely this causing the problem. I pulled the fuse for it under the dash, but this fuse also works the electric choke on the carb so I had to hook that back up. How can I stop the relay from making that noise, without either losing the electric choke or without having to hook the solenoid back up?
I was thinking maybe just putting a light bulb in place of the solenoid will complete the circuit of the solenoid circuit, and will stop the noise from happening but I'd rather fix this than patch it up like that, any ideas? Thanks guys and sorry for the long post.
:lala:
Quzyle
Oct 15, 2015 03:35 PM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Racerx974
Sep 19, 2015 10:16 AM
