Intake Bolt Patern
Old May 16, 2002 | 02:57 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Intake Bolt Patern
I'm converting from TBI to carb. I read a lot about people using RPM Air Gap manifolds and others that have a differant bolt patern than my '89 cast iron heads. I understand that the center four intake bolts are at a differant angle. Can I still use something like the RPM Air Gap that is engineered for pre 86 SBC heads? Hood clearance is not an issue, but what about the bolt pattern?
Old May 16, 2002 | 04:10 PM
Jester's Avatar
you can use pre-87 intakes on post-87 heads. You will have to elongate the 4 center holes with a dremel or die grinder, and fabricate some angled washers. OR you can have a shop mod the intake.
It's a little bit of a PITA, but it works just fine.
Also, try to trim down the sig a bit. At least to something a little less than 4x the length of your post.
Old May 16, 2002 | 04:53 PM
Max's Avatar
Max
Sounds like more trouble than it's worth. Have you heard anything about the Holley street avenger made for '87 and up heads. It is a high rise dual plane design. When I check Holley's website for the street aveng manifold it showed a weiand stealth. Are those two the same thing?
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
