Proform main body questions within...
Old Jun 9, 2002 | 01:27 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Ok, I'm getting conflicting answers on this. Summit is telling me the 67101C "750 VS" one will work with my 750 VS 4160 carb but Jegs is telling me it won't.
Will it work?
Old Jun 10, 2002 | 06:00 PM
Andy-86IROC's Avatar
What is the actual list number on your carb? The number is on the front of the choke tower...
Old Jun 10, 2002 | 08:24 PM
Car: '89 IROC-Z
The number:
80508-1
0390
Old Jun 10, 2002 | 09:27 PM
This is from the instructions;
"Before proceeding any further, you should check to be certain that your new carburetor main body will fit your carburetor. With your carburetor upside down, the throttle plates will have a number stamped on them. These numbers should be either 172 or 173. If they are not, measure the throttle bore diameter to be certain that your carburetor has 1-11/16" throttle bore. If it does not, the new carburetor main body will not work properly with the remaining components from your original carburetor."
Old Jun 11, 2002 | 06:59 AM
Car: '89 IROC-Z
Thanks I'll check that out and tell you the results...
Old Jun 11, 2002 | 12:37 PM
Car: '89 IROC-Z
The blades read 173 and the bores are 1-11/16" so 67101C is the one I order?
Old Jun 11, 2002 | 01:01 PM
There are only two models of the Proform main body, vacuum secondary and mechanical secondary (double pumper). Get the one that matches what you have.
Old Jun 13, 2002 | 05:33 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
has anyone used a proform body yet? my buddy was intrested in them. thanks.
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 02:33 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
