TPS and rough idle help!!
Old Aug 8, 2002 | 01:09 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
No matter what, I can't seem to get the car to idle smoothly, hot or cold. Here's what I've replaced so far
New AC plugs
New Cap
New rotor
New O2 sensor
New canister control valve
Good plug wires
Checked all vac lines, appear ok
Ran carb cleaner
Tried different gas
I hooked up my old analog DMM and at idle, i'm getting nearly 1 volt from the TPS. This seems to be high from what I've read. Also, with the dist wire disconnected, i'm at 1 deg base timing, but with the wire connected, I'm at 13 degs. How does this sound? Its an LG4 and the base is supposed to be at 0 deg according to the manual. The computer is showing no codes. Along with the rough idle, the idle tends to fluctuate about 75-100rpms. Please help thanx
Old Aug 10, 2002 | 02:59 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
I bought a new fuel filter today, but no help.
ttt anyone?
Old Aug 11, 2002 | 08:11 PM
flyway190's Avatar
What manual are you referring to? I have mine at 6 degrees base, you might try that.
Old Sep 7, 2002 | 06:07 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
My Helms manual and the sticker under the hood both say to set timing at 0 Deg. It seems to only run faster if I move up the timing, not smoother.
Old Sep 9, 2002 | 10:53 PM
CGCBandit's Avatar
I have the same problem with my 87 carbed formula. It's also got the LG4 motor, let meknow when you figure it out, mine has been driving me nuts, it's almost like it's got a missfire at idle.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
