High idle/Lowidle you decide
Old Aug 8, 2002 | 11:09 PM
laiky's Avatar
Firs of all i am not crazy ( at least not clinically)
when driving my 84 384 electric qjet 5speed camaro
I step on the clutch and the idle is 1500 rpm on the nose. Blipping the throttle doesnt do any thing.
if i load the engine by sliping the clutch with out adding any throttle the engine rpm will sag as load is increased until a point where it will drop sharply to 900 i step all the way down on the clutch and it idles fine at 900-1000 rpm. if i blip the throttle again it will jump to 1500 ( exactly) i load it down and it will drop and idle fine.
it seems as if something is switching as the load decraeses rpm. maybe the timing is changing? i don't know i have trouble simulating the problem once i pull the air cleaner off and the engine cools with the open hood. It was suggested that maybe the MAP sensor is failing.
any idea's???
Linson
Sep 21, 2015 01:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
adelane
Sep 9, 2015 08:51 PM
Stryker412
Sep 7, 2015 09:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
